line_rat27 Posted August 23, 2012 Share Posted August 23, 2012 quetion my buddy has a 99 accord coupe with a F22B1 inside that's not normal write that's not the engine it comes with but is it better than having the F23 inside Link to comment Share on other sites More sharing options...
Xeryon Posted August 23, 2012 Share Posted August 23, 2012 F22B1 This engine was used in the 1994-1997 Honda Accord EX and the 1997 Acura CL. It was the first F-series engine to feature VTEC. The VTEC on this engine was tuned more for fuel efficiency than performance. Specifications Bore × Stroke: 85.0 × 95.0 mm Displacement: 2156 cc Compression ratio: 8.8:1 Valve Configuration: SOHC, 16 valves (4 valves per cylinder), VTEC Max power: 145 hp (108 kW) @ 5500 rpm Max torque: 147 lb·ft (199 N m) @ 4500 rpm VTEC Switchover: 2600-5250 rpm (2-stage variable) Redline: 6200 rpm Rev limit: 6500 rpm Firing order: 1-3-4-2 Fuel control: (1994–1995) OBD-I (1996–1998) OBD-II PGM-FI F23A1 This engine was used in the 1998-2002 Honda Accord LX, EX, and SE, LEV models, and in the Acura 2.3CL in North America. Specifications Bore × Stroke: 86.0 × 97.0 mm Displacement: 2254 cc Valve Configuration: SOHC, 16 valves, VTEC Compression ratio: 9.3:1 Max power: 150 hp (112 kW) @ 5700 rpm Max torque: 152 lb·ft (205 N m) @ 4900 rpm Link to comment Share on other sites More sharing options...
line_rat27 Posted August 23, 2012 Author Share Posted August 23, 2012 ok so then some one just decided to pop out the F23 and drop a F22 in my buddy's accord? Link to comment Share on other sites More sharing options...
Xeryon Posted August 24, 2012 Share Posted August 24, 2012 The 23 was likely blown or something. The 22 would have been an easy fit, would have mated to the transmission and is readily available from any salvage yard for very little money. Too bad it's a down-grade in performance for no real increase in fuel mileage. Link to comment Share on other sites More sharing options...
line_rat27 Posted August 24, 2012 Author Share Posted August 24, 2012 ho well thanks a bunch for your input! Link to comment Share on other sites More sharing options...
