Alexander Taylor Posted June 4, 2012 Share Posted June 4, 2012 So, I got a 91 Integra that doesn't ant to start. Tried replacing the plugs and wires, but no luck. Had a guy come look at it and he said the distributor isn't throwing a spark. Replaced it, and engine still won't go. Tried spraying engine starting fluid, but nothing. Tried push starting it as well, but nothing. Not sure why the engine isn't rolling over, but it's getting a little frustrating. Any ideas? Link to comment Share on other sites More sharing options...
Xeryon Posted June 5, 2012 Share Posted June 5, 2012 Have you checked to see if the timing belt is in good shape? Double check your grounds as well. There is more then one chassis ground that needs to be secured or you will not get any spark. Link to comment Share on other sites More sharing options...
