Joshphelps91ef Posted May 14, 2012 Share Posted May 14, 2012 I have a 91 EF with a 93 ls in it. I recently changed my throw out bearing and got it all back together. I put my mid shaft in and filled the trans up with 2 quarts of 10w30 and took it for a trip round the block. When I got back I pulled in the gerage and the trans is leaking at the mid shaft hole. I put a new seal in and did the same thing and it was still leaking. Any thoughts? Link to comment Share on other sites More sharing options...
Raley Posted May 14, 2012 Share Posted May 14, 2012 im guessing you are fully seating the seal in hole. did you drain out all the old oil when you did the throw out? where did you fill at? Link to comment Share on other sites More sharing options...
Joshphelps91ef Posted May 15, 2012 Author Share Posted May 15, 2012 I got it fixed lol I went to Honda and got a new oem seal and it worked like a dream guess the other one wasn't the right size. Link to comment Share on other sites More sharing options...
