dajdmb16allday Posted April 2, 2012 Share Posted April 2, 2012 i recently rebuilt my b16a2 for my integra da, jdm vtec solenoid, jdm p30 intake manifold, typeR red valve cover, new thrust washers, new main bearings, new rod bearings, new piston rings, new oil pan gasket, new oil filter, new rear main seal, new front main seal, new tensioner pulley, new water pump, new timing belt, new head gasket, new valve cover gasket, new intake manifold gasket, new exhuast manifold gasket, new cam shaft seals, new NGK spark plugs, new dizzy, si injectors, si throttle body. just wondering how much boost can it handle on the inernals with a turbo? also how much hp/ torque will i expect from this build also i will be using ls tranny. Link to comment Share on other sites More sharing options...
Raley Posted April 2, 2012 Share Posted April 2, 2012 Ls trans will kill you. But about 10psi out of a t3/t4 60ish trim with a good tune will do about 300.... ive seen 500 on a stock b16 but would recommend it. Link to comment Share on other sites More sharing options...
