90 si-r hatch Posted March 17, 2012 Share Posted March 17, 2012 i just bought a 90 civic hatch with a jdm b16 si-r full swap with aem adjustable cam gears.. i have noticed since i had bought it that there is a pretty good vaulve tick. consistant with rpms. rpms higher the tick is faster. the wierd thing is that it seems to run fine although the idle is a bit sketchish and when it hits vtec at about 4600 rpms the tick will quit? i was reading up a bit and seen that if the cam gears are not correct it can cause the vaulves to connect with the cam or something? can this be my problem? i am just hoping this is not a big issue and thought i would see if anybody out there has expierienced this issue? i am on the search to have it retuned and timed so hopefully that will fix the problem. i am not so familiar with hondas as i am with american cars so tring to take it all in and learn.. at this point i am kinda scared to play with the cam gears because i am not exactly sure how they work or how to tune? any input will help if its something pretty simple or if i should take it to a tune shop and pay for it. thanks Link to comment Share on other sites More sharing options...
Raley Posted March 17, 2012 Share Posted March 17, 2012 its probably the valve lash, not the cam gears or timing.... Link to comment Share on other sites More sharing options...
