Zomgzack Posted February 8, 2012 Share Posted February 8, 2012 Um, so i bought this 94 del sol a little over a month ago, my first car and such, well i knew it had problems with overheating in the summer but if you let it sit for 5 to 10 mins and it would crank back up no problem, as in overheat i mean it just seems like it was getting really hot but the gauge on the dash never went into the red it would never go above half way, so i bought the car and i have been driving it back and fourth to work and i took it on a hour drive maybe 3 times and it would not crank up and get really hot after i would crank it and drive it, but if i let it sit it would crank back up, well this would happen and i didnt mind it, so i kept driving it, now it wont crank at all, its spinning but it wont fire, im thinking it could be my fuel pump or my distributor im just not very sure and this is my first car so im not that smart about them right now. Link to comment Share on other sites More sharing options...
Raley Posted February 8, 2012 Share Posted February 8, 2012 check for spark, smell for fuel in the plug holes, then run a compression check. Link to comment Share on other sites More sharing options...
Zomgzack Posted February 13, 2012 Author Share Posted February 13, 2012 turns out it was a fuel sensor, but im worried about it still overheating it does it more often in the summer, maybe the sensor will fix both problems? idk Link to comment Share on other sites More sharing options...
Raley Posted February 13, 2012 Share Posted February 13, 2012 id replace the thermostat, i think they are like 20 bucks from honda. or parts stores for like 15. do a full coolant flush too. Link to comment Share on other sites More sharing options...
Zomgzack Posted April 25, 2012 Author Share Posted April 25, 2012 thermostat is in the radiator hose right? Link to comment Share on other sites More sharing options...
Raley Posted April 26, 2012 Share Posted April 26, 2012 its on the back of the motor, the lower radiator hose goes to it... Link to comment Share on other sites More sharing options...
