brommy02 Posted September 1, 2011 Share Posted September 1, 2011 ok so i baught a d16z6 head for my 1990 honda crx and put it on my d16a6 block. for some reason i cant get it to start. i fount that there is no map sensor on it and realized i have no plug for it on my harness because my old throttle body needed a vacume line. so i put my old intake on the z6 head so that everything was hooked up and it still does the same thing. what it does is, I GOTO START IT AND IT FIRES ALL 4 CILINDERS THEN STOPS. AND IN ORDER FOR IT TO FIRE BACK UP I HAVE TO TURN THE KEY OFF AND THEN BACK ON. SO I AM THINKING THAT I DONT HAVE ENOUGH FUEL PRESSURE BUT THAT DOESNT MAKE SENSE BECAUSE THIS SWAP HAS BEEN DONE WITHOUT NEEDING A FUEL PUMP. I HAVE SPARK, DESTRIBUTER IS FINE, BRAND NEW FUEL PRESSURE REGULATOR. I ALSO CHECKED MY MAIN RELAY AND ITS FINE. WHAT IS MY PROBLEM SOMEBODY PLEASE TELL ME I HAVE BEEN WORKING ON THIS SAME PROBLEM FOR 5 MONTHS NOW!!!! Link to comment Share on other sites More sharing options...
Raley Posted September 1, 2011 Share Posted September 1, 2011 I stopped reading when it went all caps, check fuel at rail. Link to comment Share on other sites More sharing options...
brommy02 Posted September 1, 2011 Author Share Posted September 1, 2011 The caps is the important part. Nd i did a couple times the fuel rails fine. Link to comment Share on other sites More sharing options...
Raley Posted September 1, 2011 Share Posted September 1, 2011 YELLING ON THE INTERWEBZ IS USELESS. Link to comment Share on other sites More sharing options...
brommy02 Posted September 1, 2011 Author Share Posted September 1, 2011 Then ignore it asshole Link to comment Share on other sites More sharing options...
Raley Posted September 1, 2011 Share Posted September 1, 2011 Haha... you might wanna try a different site then... check honda tech ;0 hahaha.... Link to comment Share on other sites More sharing options...
brommy02 Posted September 2, 2011 Author Share Posted September 2, 2011 do you rhink that it could be my fuel pump ??? i was told that the standard si fuel pump would be enough. but i was thinking with a vtec if it lets in extra fuel during vtec it will probably need more pressure right?? i am abviously new at this. i didnt know shit till after i have put three engines in it now. but if you could i need to know all of the possible problems soon cuz i get payed today and im bad with money lol. Link to comment Share on other sites More sharing options...
Raley Posted September 2, 2011 Share Posted September 2, 2011 Sso theres fuel pressure at the rail, no idea in the cylinders id guess injectors as my shot in the dark with little info. Link to comment Share on other sites More sharing options...
brommy02 Posted September 8, 2011 Author Share Posted September 8, 2011 Ok so u think its injectors. I put the d16a6 intake on thed16z6 head so will i need to buy injectore for the d16z6 or a6 Link to comment Share on other sites More sharing options...
Raley Posted September 8, 2011 Share Posted September 8, 2011 yes... Link to comment Share on other sites More sharing options...
brommy02 Posted September 10, 2011 Author Share Posted September 10, 2011 Ok so i dont think its the injectors i think there is something electric wrong. Is there any sensors or anything electrical that wld make my car not start?? Link to comment Share on other sites More sharing options...
Raley Posted September 10, 2011 Share Posted September 10, 2011 yup, lack of electrical current. Link to comment Share on other sites More sharing options...
brommy02 Posted September 10, 2011 Author Share Posted September 10, 2011 Wht shld icheck to figure tht out Link to comment Share on other sites More sharing options...
Eighty-SixCRX Posted February 27, 2013 Share Posted February 27, 2013 Have you checked if you're getting air? If you have spark and fuel, then check to see if you have air going in, and staying in. Did you torque down your head to spec? Did you change the gasket? Are you sure the injectors are shooting fuel into the cylinder? Did you make sure your cam timing is correct? Do you have the right distributor for the new head you put on? Is your distributor rotor facing the right way for the right cylinder? Did you do your proper research before swapping the head? Hope those questions help and give you an idea as to what you can do to figure out your problem Link to comment Share on other sites More sharing options...
