B18Bommer Posted August 2, 2011 Share Posted August 2, 2011 I am having issues with the speedometer in my b18b swap. I pulled apart the speedometer housing from the trans and the speed sensor assembly. Everything looks ok and with one tire off the ground the ring gear is still moving. I tested the speed sensor itself for continuity and when rotating it its still getting readings. My next step is to try and swap out the gauge cluster since its still from the 93 dx b15 auto trans that was in there, but im outta suggestions. I need to sell my car and this is a major problem for people looking at it haha. -----> Raley : I know you can help!!! Link to comment Share on other sites More sharing options...
Raley Posted August 2, 2011 Share Posted August 2, 2011 Cluster, wiring or its not making connction at the gear Link to comment Share on other sites More sharing options...
B18Bommer Posted August 2, 2011 Author Share Posted August 2, 2011 Cluster, wiring or its not making connction at the gear It is making connection at the gear I believe. The instrument cluster is from the orignal d15 motor and automatic transmission that was originally in the car. It now has a 5 speed. Wiring is reading continuity from the VSS plus which seems ok. Should I be looking for an integra cluster, or will any 5 speed cluster work? Link to comment Share on other sites More sharing options...
Raley Posted August 2, 2011 Share Posted August 2, 2011 id guess your speedo (in the cluster) died... nothing will fit the same as a stock one... 93 dx... if you can't find one localally, lmk... id have to dig through my piles but i think i have one somewhere. Link to comment Share on other sites More sharing options...
B18Bommer Posted August 3, 2011 Author Share Posted August 3, 2011 if you found one that would be awesome! how much would you want for it? Link to comment Share on other sites More sharing options...
Raley Posted August 3, 2011 Share Posted August 3, 2011 i dunno, i gotta find it first... and ive been working my ass off lately... Link to comment Share on other sites More sharing options...
