b16a hatch Posted May 21, 2011 Share Posted May 21, 2011 i checked the relay the fuse the fan switch and the fan i jumped the fan switch and the fan turned on when i turned the key so i replace the fan switch and still no fan my car starts to overheat slowly please help thanks Link to comment Share on other sites More sharing options...
Mendy404 Posted June 8, 2011 Share Posted June 8, 2011 You may be hav a faulty wiring. Did you check that? Link to comment Share on other sites More sharing options...
Xeryon Posted June 8, 2011 Share Posted June 8, 2011 on eg and ej civics there is more then one fuse controlling fan circuitry. if the fan works when you jump it, and the temp sending unit works (your gauge is working) you need to just go to the dash fuse panel and pull and inspect each and every fuse. not just the one labeled as 'fan'. Link to comment Share on other sites More sharing options...
