NickMcIntyre Posted February 25, 2011 Share Posted February 25, 2011 Quick question. I have a 96 Accord LX. Blew engine. HAD 2.2L SOHC NON-VTEC. Put in same engine but JDM. Cant get it to start. its getting fuel and theres power at the coil but not at the plug wires. had to change the distributor to plug in to my US harness. Any suggestions? Link to comment Share on other sites More sharing options...
Turtlehead Posted February 25, 2011 Share Posted February 25, 2011 Shaft of the distributor is off 180 degrees? The teeth that stick into the cam shaft are slightly off center, make sure it is on right. It can be installed of 180 degrees and cause the car not to run so check it and rotate to distributor shaft 180 degrees if it is off and re-install. The other likely cause is the ignitor is shot. That is where I would start first given your brief description below. Link to comment Share on other sites More sharing options...
NickMcIntyre Posted February 27, 2011 Author Share Posted February 27, 2011 thanks for the tip Link to comment Share on other sites More sharing options...
Raley Posted February 27, 2011 Share Posted February 27, 2011 If you fully installed the dizzy 180 off you have a bigger problem then no spark... First check grounds, tranny to frame, valve cover to core support, strut tower to battery and most importantly, thermostat housing. If those are all good, dizzy cap, rotor, ignitor or coil. Link to comment Share on other sites More sharing options...
NickMcIntyre Posted March 4, 2011 Author Share Posted March 4, 2011 I Checked the distributor and it will only go in the camshaft one way. also i just replaced the coil, icm, cap, rotor button, plugs and wires. im getting spark and fuel but still no start. about ready to junk the car. ive run out of ideas. I Checked the distributor and it will only go in the camshaft one way. also i just replaced the coil, icm, cap, rotor button, plugs and wires. im getting spark and fuel but still no start. about ready to junk the car. ive run out of ideas. Link to comment Share on other sites More sharing options...
NickMcIntyre Posted March 4, 2011 Author Share Posted March 4, 2011 and i installed all new 4 gauge grounds 1) from batt to strut tower, 2) tranny to chassis, 3) valve cover to body, and 4) thermostat housing to batt. Link to comment Share on other sites More sharing options...
Raley Posted March 4, 2011 Share Posted March 4, 2011 all you have left is either no compression or the timing is off, how did you check if you have fuel, smell it at the tail pipe? does it make any popping sound? Link to comment Share on other sites More sharing options...
