jdeibert Posted January 31, 2011 Share Posted January 31, 2011 i have a d15 out off a 95 civic coupe and im trying to put it in a 1990 honda civic hatchback. the motor was originally obd1 and i bought a new harness from a 1990 civic si and it is obd0 will this hook up to my motor and work right please help and what else will i have to do. Thanks Link to comment Share on other sites More sharing options...
Raley Posted January 31, 2011 Share Posted January 31, 2011 no, the electrical plugs on your new motor are obd1, you need to either get a conversion harness or swap all sensors, dizzy and alternator. Link to comment Share on other sites More sharing options...
jdeibert Posted January 31, 2011 Author Share Posted January 31, 2011 but the plugs will plug in do i still need to change them and if so whats your suggestion on the easyest way to do this Link to comment Share on other sites More sharing options...
Raley Posted January 31, 2011 Share Posted January 31, 2011 A few will plug in, not all. Get the conversion harnes... what motor was in the car? Link to comment Share on other sites More sharing options...
jdeibert Posted February 1, 2011 Author Share Posted February 1, 2011 im not sure exactly what motor was in it but i know it was dpfi Link to comment Share on other sites More sharing options...
Raley Posted February 1, 2011 Share Posted February 1, 2011 Ok, that makes more work, what ecu are you gunna run? Link to comment Share on other sites More sharing options...
jdeibert Posted February 2, 2011 Author Share Posted February 2, 2011 its a p06 the same one that was with the motor before i pulled it. the harness i have now is mpfi though its from a 1990 civic si i was told that would plug rite in and work. and i do have the ecu jumper harness from rywire. Link to comment Share on other sites More sharing options...
