Pilvin Posted January 26, 2011 Share Posted January 26, 2011 I have a 2007 Honda Civic Hybrid. under 30,000 miles. Recently i got the flashing sign , check gas cap. Then I get the engine icon. I call the dealer and they want $107 to diagnose the problem. Seems pretty pricey to find out if I just need a new gas cap. Any suggestions ? Link to comment Share on other sites More sharing options...
Humphries Posted January 29, 2011 Share Posted January 29, 2011 go to autozone and ask for them to check the code. Link to comment Share on other sites More sharing options...
ATF Posted February 16, 2011 Share Posted February 16, 2011 ^^^ I need to do the same thing with my del sol. check engine light comes on frequently but my mechanic hasn't spotted a problem Link to comment Share on other sites More sharing options...
airjordan223 Posted February 16, 2011 Share Posted February 16, 2011 Yeah take it to autozone and they will pull the code for free, then google the code Link to comment Share on other sites More sharing options...
Humphries Posted February 16, 2011 Share Posted February 16, 2011 if your gas cap was loose, it's an evap code. Probably p1469 or something like that it just means your EVAP system had a leak. It doesnt affect your driving, only an emissions check. once you diagnose this, reset ECU and screw your gas cap tight every time. Link to comment Share on other sites More sharing options...
boostingcivicsi Posted February 18, 2011 Share Posted February 18, 2011 if your gas cap was loose, it's an evap code. Probably p1469 or something like that it just means your EVAP system had a leak. It doesnt affect your driving, only an emissions check. once you diagnose this, reset ECU and screw your gas cap tight every time. I agree, could be a EVAP system problem for sure. Like others said, go to AutoZone and have them check it out for you, nothing better than free! Link to comment Share on other sites More sharing options...
poonamt93 Posted February 23, 2011 Share Posted February 23, 2011 Gas caps keep crap like dust and debris out of your tank and your fuel lines which is important, also the cap keeps the gas from evaporating. they're pretty cheap, you don't have to get one from the dealer as long as it fits your car. Check out pepboys or autozone. Link to comment Share on other sites More sharing options...
