DentalDoc Posted January 19, 2011 Share Posted January 19, 2011 This has been an ongoing issue. Initially, I had the entire ABS module replaced, but then came codes 11 and 14. The right front wheel speed sensor was replaced and the light was reset. About a month after, the light comes back on with the same silly codes, 11 and 14. I know that code 11 is pointing to the FR sensor, and 14 is reporting electrical noise from the FL, but I'm really fed up with the cost now over $600. Any suggestions? Many Blessings, Dmitry Link to comment Share on other sites More sharing options...
Raley Posted January 19, 2011 Share Posted January 19, 2011 replace the lines without the abs... cut those damn sensors out and learn some pedal control. Link to comment Share on other sites More sharing options...
