Ian93EG Posted January 7, 2011 Share Posted January 7, 2011 i start it up and then it stays started for about asecond or two and then boggs down and cuts out. sounds like its getting choked. what do you think the problem could be and how to fix it? Link to comment Share on other sites More sharing options...
pinkrimedpiggy Posted January 7, 2011 Share Posted January 7, 2011 it dose this at a idle? you aren't touching the throttle at all? Link to comment Share on other sites More sharing options...
Raley Posted January 7, 2011 Share Posted January 7, 2011 Has it always done it? Stock? Which motor? Link to comment Share on other sites More sharing options...
Ian93EG Posted January 10, 2011 Author Share Posted January 10, 2011 like i start it up and it starts idleing for about 1-3 seconds sumtimes less and then boggs down and cuts off. it sounds like somthing is chokeing it. it is a stock d15b7 non vtech motor 1.5L. all it has done to it is a cold air intake and magna flow exhuast system, i just put new headers on it, bottom and top. but it has dones this before that. and most the it started towards the begining of fall and those times u would just wait for a few hours and try again and it would work fine again for a month or two like nothing happened. but i have sprayed carb cleaner into the throttle body and intake manifold and it helped the firdt time it did it. aand now i did that again and i cleaned the idle control valve and it still wont keep started. i also put a brand new fuel filter on it like a monthe or two ago. some guy at pep boys said to try a new fuel filter again instead of getting a new fuel pump but i just rather wanna know what is making the problem and getting that fixed so i can roll again lol Link to comment Share on other sites More sharing options...
Ian93EG Posted January 10, 2011 Author Share Posted January 10, 2011 and if u tap the throttle just a little bit quickly it will keep going as long as u keep doing so but i can move it at all, but wen u press the pedal down even more it will just bogg down also and cut out and off like it does anyways. Link to comment Share on other sites More sharing options...
