eg4door Posted December 26, 2010 Share Posted December 26, 2010 ok i have a b16a in my civic, the car ran great, then the timing belt slipped, i thought i bent a valve, so i put a new head on, the head came off an lsv setup, it has super tech valve springs, etc. since i put the head on i have no vtec, there is no check engine light on, i try to do a few things to test it, like put a new ground, fuel filter, fresh oil change, cleaned the screen. i was told about the lost mostion assemably. i need more ideas of what i can do before tearing the head back off. Link to comment Share on other sites More sharing options...
Trae%eh6 Posted December 26, 2010 Share Posted December 26, 2010 first thing that comes to mind is that you said it came off a lsv well that means the head is tap. what did you do about that tap. something eles too did you plug up your vtec solenoid. did you buy the car with the swap? if so do you know if the cel is even in the gauge clusters. also run a code reader on the car just to make sure your not throwing them. Link to comment Share on other sites More sharing options...
eg4door Posted December 26, 2010 Author Share Posted December 26, 2010 i saw that is was tapped, i plugged it up, i took the plug out of the old head, no i swapped the car my self. no i did not plug up my vtec solenoid. question, what is cel. i know when i got the car the gauge cluster didnt work right so i put a new one in, an seems to be working fine. Link to comment Share on other sites More sharing options...
Raley Posted December 26, 2010 Share Posted December 26, 2010 Cel is check engine light. Link to comment Share on other sites More sharing options...
eg4door Posted December 26, 2010 Author Share Posted December 26, 2010 yes the car has the cel in the cluster, it cycles threw, light comes on then goes off. i did unplug the pressure switch just to see if it would threw a code an it did. Link to comment Share on other sites More sharing options...
Trae%eh6 Posted December 26, 2010 Share Posted December 26, 2010 your vtec solenoid maybe it went bad or something try a new one. other than that i dont know what it could be sorry Link to comment Share on other sites More sharing options...
Humphries Posted December 30, 2010 Share Posted December 30, 2010 check oil level. Link to comment Share on other sites More sharing options...
eg4door Posted January 4, 2011 Author Share Posted January 4, 2011 i did a fresh oil change. i ohm out the pressure switch would the head being on an lsv setup have to do with anything, like oil pressure Link to comment Share on other sites More sharing options...
