biglfla Posted November 29, 2010 Share Posted November 29, 2010 ok i have a 95 lx 2.2 non vtech the cam siezed in the head while i was driving it (right after i purchased it ) so i went and got a head from the junkyard changed it out w/ new gasket and timing belt now im getting spark and fuel to the rail but the vehicle is not starting a very disturbing situation indeed i tried both cam sensors (at least i think it was the cam sensor right next to the coolant temp sens) and still no luck any suggestions would be greatly appreciated thank you Link to comment Share on other sites More sharing options...
Raley Posted November 30, 2010 Share Posted November 30, 2010 compression? could have screwed up the bottom end when the head crapped out on ya. Link to comment Share on other sites More sharing options...
Turtlehead Posted December 1, 2010 Share Posted December 1, 2010 Make sure the distributor is not off 180 degrees. Link to comment Share on other sites More sharing options...
Hia Posted December 18, 2010 Share Posted December 18, 2010 ok i have a 95 lx 2.2 non vtech the cam siezed in the head while i was driving it (right after i purchased it ) so i went and got a head from the junkyard changed it out w/ new gasket and timing belt now im getting spark and fuel to the rail but the vehicle is not starting a very disturbing situation indeed i tried both cam sensors (at least i think it was the cam sensor right next to the coolant temp sens) and still no luck any suggestions would be greatly appreciated thank you Check main relay (for fuel pump). Honda have problem with main relay. Link to comment Share on other sites More sharing options...
