gdannboy Posted November 27, 2010 Share Posted November 27, 2010 Hi does anyone know what my car's problem is, i put new rotors and break pads and after that my car makes noise when i break like a high pitch sounds and stops when i stop breaking. the thing is that i bought ceramic break pads so it shouldnt be making noise. Ive been driving it for a couple months so its not that the break pads aren't broken in yet. I also think there is a separate noise when i go forward. Does anyone know what this could be? Link to comment Share on other sites More sharing options...
airjordan223 Posted November 27, 2010 Share Posted November 27, 2010 Did you use anti squeal grease on the shims? Link to comment Share on other sites More sharing options...
gdannboy Posted November 28, 2010 Author Share Posted November 28, 2010 Did you use anti squeal grease on the shims? I don't think so, my mechanic put everything in. Is there a way i can add some sort of grease without taking the brake pads off? Link to comment Share on other sites More sharing options...
lastresort576 Posted November 28, 2010 Share Posted November 28, 2010 I don't think so, my mechanic put everything in. Is there a way i can add some sort of grease without taking the brake pads off? yup. the brake pads can stay in place while you put anti squeal on. you just gotta remove/slide the caliper up on the slide pin. Link to comment Share on other sites More sharing options...
Escape-performance Posted November 28, 2010 Share Posted November 28, 2010 I use the orange anti squeal, it seems to work best if you let is "set" a couple minutes after putting it on the back of the pads. You usually only get squeal with cheap pads, are you sure your mechanic put in ceramics? Link to comment Share on other sites More sharing options...
