GM2000 Posted November 19, 2010 Share Posted November 19, 2010 Is there a way to clear my check engine light without taking it to a shop? Link to comment Share on other sites More sharing options...
mpearce1974 Posted November 19, 2010 Share Posted November 19, 2010 Is there a way to clear my check engine light without taking it to a shop? Remove negative cable from battery for a few minutes. Depending on what the problem is, it may stay away or come back immediately? Is this so you can pass inspection?? If they hook up scanner to system even if light is off, I am thinking it will still have information stored (I could be wrong) Personally it is on for a reason and I would take to like AutoZone or somewhere that will scan for free with hand held scanner. Not terribly accurate, but will point you in right direction...... Link to comment Share on other sites More sharing options...
GM2000 Posted November 19, 2010 Author Share Posted November 19, 2010 Remove negative cable from battery for a few minutes. Depending on what the problem is, it may stay away or come back immediately? Is this so you can pass inspection?? If they hook up scanner to system even if light is off, I am thinking it will still have information stored (I could be wrong) Personally it is on for a reason and I would take to like AutoZone or somewhere that will scan for free with hand held scanner. Not terribly accurate, but will point you in right direction...... Link to comment Share on other sites More sharing options...
