netbret Posted November 18, 2010 Share Posted November 18, 2010 I've got a problem with my 95 sol. I can lock the driver side door with the key but I'm unable to open it with the handle. When I'm inside, I can open it fine. I did notice that the door handle doesn't pull the "bent" shaft as far as when your inside. If you look at item #14, that appears to be some type of adjustment that goes into the shaft below that's threaded on top. Any ideas? Link to comment Share on other sites More sharing options...
Raley Posted November 18, 2010 Share Posted November 18, 2010 There is adjustment of about an inch there but my guess is your handle is about to go... the pivot location tears out of the plastic pretty easy. Link to comment Share on other sites More sharing options...
netbret Posted November 18, 2010 Author Share Posted November 18, 2010 There is adjustment of about an inch there but my guess is your handle is about to go... the pivot location tears out of the plastic pretty easy. I know where the tear out area is, and can you just pull out that pivot with a long set of pliers and manually turn it? Link to comment Share on other sites More sharing options...
