bbv22001 Posted October 17, 2010 Posted October 17, 2010 1989 accord lxi 213000 mi I had a bit of a high idle and was looking around the forums and saw some suggestions about resetting the ecu and using idle screw, and this might be a crazy coincidence but now i am getting small ammounts of cooland squirting up from around the belts. Not sure if i could have done this, seems unlikley but PLEASE HELP IF YOU CAN. Oh and car has not overheated. Aaron
Bravesball20 Posted October 17, 2010 Posted October 17, 2010 1989 accord lxi 213000 mi I had a bit of a high idle and was looking around the forums and saw some suggestions about resetting the ecu and using idle screw, and this might be a crazy coincidence but now i am getting small ammounts of cooland squirting up from around the belts. Not sure if i could have done this, seems unlikley but PLEASE HELP IF YOU CAN. Oh and car has not overheated. Aaron Hmm when my 95' accord starting leaking around the belts of a small hole on the side of the engine that meant that the Water pump was failing. Not saying it has but maybe your water pump is a fail...
