Lemurskin Posted September 11, 2003 Share Posted September 11, 2003 Hello all- I am having a starting problem on my wife's 91 Civic. It starts right up but when the key is returned back the 'II" position, the engine dies. I have swapped many parts off my 89 Civic during this process- coil, ignitor and main relay to name a few. I noticed that when the key is in the "II" position, there are no idiot lights on. If I turn the key just past this position but not engaging the starter, the lights come on. I also found out that the engine will stay running if I hold the key in this midway position after starting. The radio and A/C do not work while doing this though. I am thinking it has some thing to do with the ignitions switch. Thanks in advance. Link to comment Share on other sites More sharing options...
TLontheDL Posted September 11, 2003 Share Posted September 11, 2003 yes, i believe it has to do with your ignition switch. i dont think its your starter b/c you said your engine does start. could be bad spark plugs or ignition wires. Link to comment Share on other sites More sharing options...
Lemurskin Posted September 21, 2003 Author Share Posted September 21, 2003 Looks like it was the ignition pig-tails(switch on back of lock mech). Bought a new one from dealer- $56. Link to comment Share on other sites More sharing options...
