kyleb123 Posted March 14, 2010 Share Posted March 14, 2010 i have a 1997 honda ex v6 accord and when i drive and turn right it makes a clunk/clicking noise. when i turn right on smoth payment there is no sound. can anyone help me finding the issue and the solution on solving the problem. Quote Link to comment Share on other sites More sharing options...
Xeryon Posted March 14, 2010 Share Posted March 14, 2010 If the noise is a single occurrence and does not repeat in rhythm to the speed of your car you are most likely in need of some new tie rod ends. Nothing terrible, but don't let it go for too long. Eventually it will break and that will be bad news if you are on the freeway doing 70. Quote Link to comment Share on other sites More sharing options...
James Matteu Posted March 15, 2010 Share Posted March 15, 2010 Possible sources for your noise: Tie Rod Ends (already mentioned above, good call) CV Axles - check the boots on both sides, they should be dry and in one piece. Lug Nuts - make sure you have 4 on each wheel Quote Link to comment Share on other sites More sharing options...
Xeryon Posted March 15, 2010 Share Posted March 15, 2010 CV Axles - check the boots on both sides, they should be dry and in one piece. Lug Nuts - make sure you have 4 on each wheel To add to this: Both of these problems are generally accompanied by regularly repeating noise as the source of the sound is a rotating part and the trigger will repeat with every revolution of the wheel. Not in all cases, but that is the status quo. Quote Link to comment Share on other sites More sharing options...
drawk04 Posted March 15, 2010 Share Posted March 15, 2010 To add to this: Both of these problems are generally accompanied by regularly repeating noise as the source of the sound is a rotating part and the trigger will repeat with every revolution of the wheel. Not in all cases, but that is the status quo. sounds like a cv axle.......my tie rods were shot when i bought mine and they never clicked....and even if the shaft appears dry and the boots are untorn, that doenst mean its not messed up. just replaced my passenger side cv axle and the boot was in tact and there was nothing visable to say it was messed up. good luck. Quote Link to comment Share on other sites More sharing options...
Turtlehead Posted March 19, 2010 Share Posted March 19, 2010 Check the sway bar links and bushing to the sub frame. Quote Link to comment Share on other sites More sharing options...
cranny Posted March 19, 2010 Share Posted March 19, 2010 Check the sway bar links and bushing to the sub frame. Quote Link to comment Share on other sites More sharing options...
