culprit00 Posted February 14, 2010 Share Posted February 14, 2010 Hey Guys I have a 5th Gen JDM accord that come stocked with the H22 motor, now the thing is I dont know when the VTEC kicks in because the engine sounds the same until I redline. Now I kow the VTEC works becuase when I plug out the Green plug that runs to the solenoid the card does not pass 6000 RPM. WHen I Plug it in I can go all the way till the rev limiter kicks in, however I cannot hear the dfference. ( My VTEC solenoid seal/gasket leaks oil as well, can this be why? I know guys who's gasket leaks but you can still hear when thier VTEC engages) Link to comment Share on other sites More sharing options...
Velocifero Posted February 17, 2010 Share Posted February 17, 2010 Hey Guys I have a 5th Gen JDM accord that come stocked with the H22 motor, now the thing is I dont know when the VTEC kicks in because the engine sounds the same until I redline. Now I kow the VTEC works becuase when I plug out the Green plug that runs to the solenoid the card does not pass 6000 RPM. WHen I Plug it in I can go all the way till the rev limiter kicks in, however I cannot hear the dfference. ( My VTEC solenoid seal/gasket leaks oil as well, can this be why? I know guys who's gasket leaks but you can still hear when thier VTEC engages) Supposed to be a noticeable difference at 5200 RPMs. If you're leaking sh*t around the VTEC solenoid, that could be the problem as VTEC is oil pressure driven. Link to comment Share on other sites More sharing options...
