mt98 Posted February 3, 2010 Share Posted February 3, 2010 I have a 98 Accord,auto trans,4cyl. When the car is first driven the trans does not want to shift out of 1st gear,when it does it is a slightly harder shift than normal.Does not do it after being driven a while.Trans was rebuilt when previous owner had car, approx. 3 years ago. It also makes a noise at idle in park and neutral that goes away when in gear,sounds like a bad bearing, for lack of better description. Any ideas ? Torque converter, trans,bad rebuild? Thanks for looking Mike T Link to comment Share on other sites More sharing options...
Xeryon Posted February 3, 2010 Share Posted February 3, 2010 The obvious first question: Have you checked the fluid level? And when you did was the fluid a clear pink color or was it a dirty brown or grayish? Link to comment Share on other sites More sharing options...
mt98 Posted February 4, 2010 Author Share Posted February 4, 2010 The obvious first question: Have you checked the fluid level? And when you did was the fluid a clear pink color or was it a dirty brown or grayish? Fluid level is fine,fluid was changed 5,000 miles ago, before this started happening. Thanks Link to comment Share on other sites More sharing options...
Xeryon Posted February 4, 2010 Share Posted February 4, 2010 Sadly, automatic transmissions are something I have almost no experience with so I am not going to be much more help. For the record: Honda apparently had quite a few issues on and off with the transmissions in your generation of Accord. Link to comment Share on other sites More sharing options...
