REDBULLx69 Posted January 27, 2010 Share Posted January 27, 2010 i just bought a set of skunk2 pro s coilovers for my 05 civic lx, put them in the other day, and set the perches all the way down in the front, and have a few threads left in the back. i still have wheel gap with stock steelys :'( i can fit 2 fingers under the fender. i did have tein s tech springs in, and now the coilovers dont look much lower. alot stiffer, but maby an inch lower. is there something im not doing right or is this as low as they go? the website said they drop 3 inches and im kinda dissapointed... Link to comment Share on other sites More sharing options...
Xeryon Posted January 27, 2010 Share Posted January 27, 2010 Not sure if we have a word definition issue here, but when you adjust most coilovers you do not adjust the spring perch. The shaft of the lower assembly itself should thread up into the bottom of the upper assembly but the perches should remain at the factory position unless you know what you are doing with adjusting spring rates. Link to comment Share on other sites More sharing options...
REDBULLx69 Posted January 27, 2010 Author Share Posted January 27, 2010 the only thing i can adjust on these is the perches. nothing else is adjustable. well that i know of but it really doesnt look like it heres the front... about 1 thread left on the coilovers ( gotta love the hubs customly painted by yours truly heres the back...about 8 or so threads left (some guy backed into me today so i have an effed up fender :'( Link to comment Share on other sites More sharing options...
Xeryon Posted January 27, 2010 Share Posted January 27, 2010 If you have the full coilover kit it will have looked like these: Notice how the spring perch is a two part nut, it is not supposed to be adjustable. The lower nut is where you loosen and change the height of the assembly. Or did you install just the adjustable coil kit and not the full coilover assembly? Link to comment Share on other sites More sharing options...
REDBULLx69 Posted January 30, 2010 Author Share Posted January 30, 2010 mines def not like that. heres the link to them where i bought them. http://www.procivic.com/pages-product_car_part_info/category-69_80/product-324/index.html see theyre completely different. plus mine didnt come with the full top hat peice. i had to use the stock one. Link to comment Share on other sites More sharing options...
Xeryon Posted January 30, 2010 Share Posted January 30, 2010 Actually, the ones shown on your link are similar. Just a different model line. Picture is a little small to see where they should adjust, but you shouldn't be adjusting the spring perch for height. Link to comment Share on other sites More sharing options...
REDBULLx69 Posted February 1, 2010 Author Share Posted February 1, 2010 heres a better picture of them from google http://www.weaksauceparts.com/store/images/t_18337.jpg but if im not supposed to move the perches then what am i supposed to adjust for ride height? nothing else moves on them Link to comment Share on other sites More sharing options...
Xeryon Posted February 2, 2010 Share Posted February 2, 2010 On mine the entire shock body is threaded and the lower mount threads onto the threaded shock body. I just rotate the shock body itself to raise the car up and down. Obviously, we are not comparing identical products so yours just may not function the same. Here are mine. Notice the gold set screw just below the spring perches. On mine I just loosen that and rotate the body. Car goes up and down with one hand. Link to comment Share on other sites More sharing options...
REDBULLx69 Posted February 4, 2010 Author Share Posted February 4, 2010 yea mine def does not do that. guess i got the cheap rip off brand but idk maby i can fool around with them and see what i can do. maby i can take the bottom perch out to lower it a little more? since theres two i can roll with one. woo lowered 0.002 more inches Link to comment Share on other sites More sharing options...
