juno312 Posted September 3, 2003 Share Posted September 3, 2003 I wanted to know if the cats are required for my 97 civic because I wanted to put a off road midpipe on it and if I do how much hp will I gane. Link to comment Share on other sites More sharing options...
Trepid Posted September 3, 2003 Share Posted September 3, 2003 yes, they are required, but I don't know the laws of nevada as far as smogging your car is concerned Link to comment Share on other sites More sharing options...
joecollins2 Posted September 3, 2003 Share Posted September 3, 2003 Check with the county you live in. In the county I live in now, emissions is not required so you can do whatever you want. In the county I used to live in it was required so you had to have a cat and a muffler. So it varies by county so check your local laws. Link to comment Share on other sites More sharing options...
optional187 Posted September 3, 2003 Share Posted September 3, 2003 Check with the county you live in. In the county I live in now, emissions is not required so you can do whatever you want. In the county I used to live in it was required so you had to have a cat and a muffler. So it varies by county so check your local laws. you mean state? cat's are not required for your engine to run. but they are required in order to pass smog tests. if you live in a state that doesn't make you pass a smog check then go for it, otherwise you're screwed and fined when you do get smogged. you don't have to go through a smog check in florida... Link to comment Share on other sites More sharing options...
juno312 Posted September 3, 2003 Author Share Posted September 3, 2003 Thank you all for your info and it was helpful. But if I put the off road midpipe how much horsepower will I gain. Link to comment Share on other sites More sharing options...
joecollins2 Posted September 4, 2003 Share Posted September 4, 2003 you mean state? you don't have to go through a smog check in florida... No, the county I live in, in Indiana does not require emissions testing. However, the next county over, where I used to live, still in Indiana does require it. I know in some states it varies by county... Link to comment Share on other sites More sharing options...
optional187 Posted September 5, 2003 Share Posted September 5, 2003 you mean state? you don't have to go through a smog check in florida... No, the county I live in, in Indiana does not require emissions testing. However, the next county over, where I used to live, still in Indiana does require it. I know in some states it varies by county... ohhh sorry...i was reading "county" as "country" Link to comment Share on other sites More sharing options...
juno312 Posted September 5, 2003 Author Share Posted September 5, 2003 Link to comment Share on other sites More sharing options...
joecollins2 Posted September 5, 2003 Share Posted September 5, 2003 ohhh sorry...i was reading "county" as "country" HUKD ON FONIKS WURKD FOUR MEE!! Link to comment Share on other sites More sharing options...
JDM Jackass2 Posted September 9, 2003 Share Posted September 9, 2003 um YES cats are required or your secondary O2 sensor will throw a code if your rice mobile is 96+. thanks NOBODY for bringing that up. Link to comment Share on other sites More sharing options...
