shak3yb0n3z Posted January 10, 2010 Share Posted January 10, 2010 So I finally got my swap all done and the exhaust good to go today. The only problem I'm having with my swap now is when I turn I get a binding noise coming from the trans. At first I thought it was the axles, but after going thru 3 sets of axles (last set came off another prelude) I'm starting to suspect maybe the planetary gears in the LSD. I have a 1998 Honda Prelude Type SH. I pulled my engine and trans and swapped in a JDM H22A with a factory LSD trans. My swap came with the halfshaft also. The car drives fine in a straight line, but as soon as turn i get this horrible binding noise. it only happens in gear under acceleration. As soon as i pull it out of gear or put my foot on the clutch, it goes away. If I put the car on a lift it will not make this binding noise either. It also doesn't appear to do it in reverse. Tomorrow morning I'm going to pull the transmission and take it apart to see what I can find. In the event I can't get this trans running tomorrow, does anyone know for a fact if i can put my USDM transmission (that came off the prelude SH) on my JDM swap without any problems? Any help is greatly appeciated. Thanks in advance. Link to comment Share on other sites More sharing options...
shak3yb0n3z Posted January 10, 2010 Author Share Posted January 10, 2010 wow nobody eh? Good thing I figured it out! Link to comment Share on other sites More sharing options...
lceah Posted January 11, 2010 Share Posted January 11, 2010 Go to this late...sorry... What happened? Link to comment Share on other sites More sharing options...
