hemz86 Posted August 28, 2003 Share Posted August 28, 2003 I have two problems one is much bigger than the other. First of all the lesser of the two is my 98 Dx is suffering from misaligned headlights and i bought the car used so i have no manual how do i adjust the headlights. Second, off and on now my car seems to be making a slight rattling noise coming from the engine bay, the oil is bout 1/4 full and is due for an oil change. Is this causing the noise or do you have any other ideas, seems to be coming from the right side of the engine. Belts were just checked so don't think that it is them. It only happens off and on not every time around 2000 rpm in 1st and neutral but seems to go away after that. Please help Link to comment Share on other sites More sharing options...
Amler Posted August 28, 2003 Share Posted August 28, 2003 I have two problems one is much bigger than the other. First of all the lesser of the two is my 98 Dx is suffering from misaligned headlights and i bought the car used so i have no manual how do i adjust the headlights. Second, off and on now my car seems to be making a slight rattling noise coming from the engine bay, the oil is bout 1/4 full and is due for an oil change. Is this causing the noise or do you have any other ideas, seems to be coming from the right side of the engine. Belts were just checked so don't think that it is them. It only happens off and on not every time around 2000 rpm in 1st and neutral but seems to go away after that. Please help You might want to fill your oil up the noise could very well be you valves going nuts because they aren't getting any oil lube up there, and that means bad news. Link to comment Share on other sites More sharing options...
optional187 Posted August 28, 2003 Share Posted August 28, 2003 on the right side of the engine bay? could this be...........transmission? does it make the noise when you let the clutch out, or when its pressed in. i'm assuming when its out because you say it also does it in first gear. Link to comment Share on other sites More sharing options...
hemz86 Posted August 28, 2003 Author Share Posted August 28, 2003 its when the clutch is out, the car is still under warrenty for like 3 more weeks so i figure i'll change the oil this weekend and if no luck get it checked out. Any help w/ the lights>? Link to comment Share on other sites More sharing options...
civi93ex Posted August 28, 2003 Share Posted August 28, 2003 my car makes that noise too, but im pretty sure it is the transmission cause my 3rd gear synchro is out so there is alot of grinding Link to comment Share on other sites More sharing options...
optional187 Posted August 28, 2003 Share Posted August 28, 2003 if your car is still under warranty then take it to the dealership before it runs out... Link to comment Share on other sites More sharing options...
ImportGirl82 Posted August 31, 2003 Share Posted August 31, 2003 if your car is still under warranty then take it to the dealership before it runs out... yeah if i were u i would take it to get fixed...you got a warranty so i would..better then fronting the parts than you Link to comment Share on other sites More sharing options...
jackasssi Posted August 31, 2003 Share Posted August 31, 2003 I have two problems one is much bigger than the other. First of all the lesser of the two is my 98 Dx is suffering from misaligned headlights and i bought the car used so i have no manual how do i adjust the headlights. Second, off and on now my car seems to be making a slight rattling noise coming from the engine bay, the oil is bout 1/4 full and is due for an oil change. Is this causing the noise or do you have any other ideas, seems to be coming from the right side of the engine. Belts were just checked so don't think that it is them. It only happens off and on not every time around 2000 rpm in 1st and neutral but seems to go away after that. Please help 1/4 of the capacity? WTF are you thinking . . . Proper maintenance is key To answer your first question, there are 2 screws on each headlight(vertical/horizontal adjustment screws). Pull your car 10 feet away from a wall, parked on a level surface. Then go about do your bidness adjusting. Most likely the rattling noise is a loose heatshield. When the car is cool tap on the heatshields, if its loose then thats your problem. When was the last time you had a valve adjustment or any maintenance besides missed oil changes? Take your car to Honda for the next oil change. They will let you know of all recommended repairs/maint, decline the work & do-it yourself. How do you do it yourself? www.helminc.com - get yourself a factory repair manual. Link to comment Share on other sites More sharing options...
hemz86 Posted August 31, 2003 Author Share Posted August 31, 2003 The heat shields would be located where exaclty? Link to comment Share on other sites More sharing options...
