mateo710 Posted September 10, 2009 Share Posted September 10, 2009 ok so i plan on rebuilding the bottom end of a B18c JDM gsr engine because of a thrown rod. but since the rod is thrown does that mean i need to remachine the head to? should i replace the bearings while im at it? Link to comment Share on other sites More sharing options...
SpeedDemon Posted September 10, 2009 Share Posted September 10, 2009 depends on how bad it is. if there is evident damage to the head then yes. if you cant really tell yo ucan risk it. but since you did throw a rod i would just go ahead and get it done anyways. it never hurts Link to comment Share on other sites More sharing options...
cranny Posted September 11, 2009 Share Posted September 11, 2009 if you threw a rod , and your lucky , the head will be the only thing left any good most likely. there is no rebuilding that bottom end. Link to comment Share on other sites More sharing options...
