true-bluecb7 Posted August 17, 2009 Share Posted August 17, 2009 So on my old CB cluster, the odometer/tripometer stopped working. I swapped that part out and got another one (off a 9091 cluster, and mine's '92) The 9091 cluster was made by NS, as well as my 9293 cluster. Issue is: it spins faster than it should! From my girlfriend's house, to mine, is 12-ish miles. I reset it (since it was fixed there) and trip read at almost 27 miles. WTF? :help: Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted August 17, 2009 Share Posted August 17, 2009 is your speedometer off as well or just the odometer? Quote Link to comment Share on other sites More sharing options...
wannaBstuntin Posted August 17, 2009 Share Posted August 17, 2009 Aw, don't feel so bad... Quote Link to comment Share on other sites More sharing options...
true-bluecb7 Posted August 17, 2009 Author Share Posted August 17, 2009 is your speedometer off as well or just the odometer? Just the odometer/tripometer. Aw, don't feel so bad... lol why? Quote Link to comment Share on other sites More sharing options...
Turtlehead Posted August 19, 2009 Share Posted August 19, 2009 I know I am a little late to respond. 1. are the tire diameters on each model the same, 2. if so, then a. the VSS is bad or b. the spedo head recently put in is bad. Quote Link to comment Share on other sites More sharing options...
true-bluecb7 Posted August 21, 2009 Author Share Posted August 21, 2009 (edited) I know I am a little late to respond. 1. are the tire diameters on each model the same, 2. if so, then a. the VSS is bad or b. the spedo head recently put in is bad. 1: Yes. 2. a. The VSS? Sure? My speedo's fine... weird. b. I only changed the tach and odo/trip part... On CBs, the odo/trip part is separate from the speedo. Edited August 21, 2009 by true-bluecb7 Quote Link to comment Share on other sites More sharing options...
