CRX_Rocket Posted July 7, 2009 Posted July 7, 2009 Hey Guys, Ive Been Messing with this dam spindle nut on my 89 CRX and for what ever reason i can not get it off. Ive Tried a couple things, starting with using a prybar and breaker bar to try and remove the dam thing, i cant seem to get it off, i stuck the prybar between the studs as close to the rotor as possible to avoid breaking the stud and at this point i was litterally lifting the car off the ground, im not sure where to go from here, i could use an impact but honestly would that be any diffrent than a 200lb guy and a breaker bar? I could be wrong, but any ways any help would be awsome! Thanks in advance Al.
alex37211 Posted July 7, 2009 Posted July 7, 2009 An impact is a whole lot different. It works in a much different way. Even a weak impact can be more effective than a big strong dude. Also, spray some penetrate on it. PBlaster works well. Or seafoam deep creep.
Kastigir Posted July 7, 2009 Posted July 7, 2009 Impact wrench, 32mm socket, and presto it comes right off. You don't even need penetrating oil.
CRX_Rocket Posted July 7, 2009 Author Posted July 7, 2009 Allright well im gona give it a shot tonight after work, i gotta get some things so i hope this works, Thanks, and yea ive used PB plaster that stuff works wonders thanks guys
rx7turbo287 Posted July 26, 2009 Posted July 26, 2009 i always use a good size screwdriver and put it in the brake and so the rotor won't turn, the hole at the calibers and rotor fan slot) then a 32mm with a long breaker bar, and stand on it, bounce on it few time. it worked on every honda i every came across. but impact with work for sure, and there's a different between hands taking it off and impact it off. u can always use a hammer hit on the bar too, it kinda act like a impact. that works on my crank pulley bolts.
