hiemsnox Posted June 16, 2009 Share Posted June 16, 2009 ok so i recently bought another del sol and it came with almost all the turbo parts... and last night in my boredom i installed it all... but i know im missing some parts so if you can try your best and identify what im missing that would be amazingly helpfull ___ITEMS INSTALLED___ Mani with turbo and wastgate intercooler and all piping oil feed line with spliter in for oil sending unit oil pan is tapped ___ITEMS NOT INSTALLED OR DONT KNOW WHERE THEY GO___ (ill try to show picture with number relating) 1. It says Vacum on the top of the wastegate... i dont know what goes there or where it connects 2. Oil Lines i have only the feed line installed but there are 2 other ones(will replace to steel from rubber) but what i dont know is which one goes to the return in the oilpan and where the other one goes 3. ON the turbo there is a much bigger connector for piping... i cant get a picture anymore but i dont have the slightest idea what it is. (its not the air intake or cool side exit) 4. There is a bung hold that isnt used on the intake mani. so basically does anyone know turbos well enough to be sure of all the lines used? 1. 2. / 3. 4. Quote Link to comment Share on other sites More sharing options...
Kastigir Posted June 16, 2009 Share Posted June 16, 2009 The vacuum line for the wastegate will need to run to a vacuum source, there should be a covered nipple on the intake that can be used. Do you have a picture of the oil lines, because whichever one is facing down should be your drain, the other port could be a coolant line because many turbos are water cooled as well. Quote Link to comment Share on other sites More sharing options...
lceah Posted June 16, 2009 Share Posted June 16, 2009 You are missing Blow Off Valve... I can't see the pics because I'm at work, so if it's in the pics, then ok. Quote Link to comment Share on other sites More sharing options...
hiemsnox Posted June 16, 2009 Author Share Posted June 16, 2009 The vacuum line for the wastegate will need to run to a vacuum source, there should be a covered nipple on the intake that can be used. Do you have a picture of the oil lines, because whichever one is facing down should be your drain, the other port could be a coolant line because many turbos are water cooled as well. ok well that answered 2 questions at once for the most part cause in the last pic shown there is another nipple that isnt being used on the intake manifold, and as return line i think i can pick out what that is. but there is still another line that looks like oil. and if its as u say water cooled that might explain the larger port on the turbo(the one w/o a hose)... but i still need to find out what that other hose is and Iceah i do have a BOV i just didnt show the charge pipe Quote Link to comment Share on other sites More sharing options...
