nightshift customs 95 Posted June 14, 2009 Share Posted June 14, 2009 So I've got a question...I have a B18C head and I keep leaking oil out of the distributor cap, I even bought a new distributor and it still does it. Are there different sizes of shafts or is it something to do with the seals? Also, the valves are from ebay, so I'm thinking there might be an issue with the leak-down in the cylinders and valves, or maybe an issue with the valve guides. I'm really confused and worried. Please help me!! Link to comment Share on other sites More sharing options...
Kastigir Posted June 14, 2009 Share Posted June 14, 2009 There is an O-ring on the shaft of the distributor itself, it has failed. You need a new one. Link to comment Share on other sites More sharing options...
SIR_VTEC Posted July 8, 2009 Share Posted July 8, 2009 Its definately your O-ring Link to comment Share on other sites More sharing options...
cranny Posted September 30, 2009 Share Posted September 30, 2009 you guys dont listen. he says its leaking from the cap , and he installed a new dizzy with the same problem. is it leaking from the cap or where the dizzy meets the head? how does it run? does it puff smoke out the exhaust? if so what color? Link to comment Share on other sites More sharing options...
