hessey0788 Posted June 7, 2009 Share Posted June 7, 2009 how much do k20a3 motors and ecu go for i had asked this question on crannys page hoping he would see it and say something since he did a k swap but he didnt like me posting on his thread i had a guy tell me 550 for one and does anyone know if it will fit in the del sol without having to be a fabrication specialist. this could be going into my other del sol so thanks for any info Quote Link to comment Share on other sites More sharing options...
alex37211 Posted June 7, 2009 Share Posted June 7, 2009 (edited) that's def a good deal. I've seen a3 swaps around $1k-$1200 @ the cheapest. I sold an a3 swap for $2k. Kinda got lucky. There is some extra work involved in a k-swap. It would be the same as doing it in a 92-95 civic or 94-01 teg if that helps with finding info. With the mount kits available, I don't believe you gotta cut or weld anything but I could be wrong. I know you have to fasten the shifter cable box under your car. I don't know if there are bolt on adaptors yet. Edited June 7, 2009 by alex37211 Quote Link to comment Share on other sites More sharing options...
cranny Posted June 7, 2009 Share Posted June 7, 2009 (edited) not that i didnt like it , just not the right place for it , and if you want answers your better off starting your own thread instead of burying your question in a 23 page thread , lol. there is lots of info on this in alot of different places. not a cheap swap at all. youl need the engine/tranny , and full engine/charge wiring harness for K series. the axles are no good to you. your better off buying everything you need in a package from hasport , like axles , mounts , conversion harness , etc. and youl still need shifter box and cables from an rsx. karcepts shifter adapter kit. Hondata Kpro. youl need an aftermarket fuel rail in order to run a K series in any civic 00-down(this includes you). you would not want to try and do this swap yourself if your not WELL versed in hondas or K series in general. or swaps for that matter. Edited June 7, 2009 by cranny Quote Link to comment Share on other sites More sharing options...
hessey0788 Posted June 7, 2009 Author Share Posted June 7, 2009 enough said then i probably wont consider doing it then ill stick with throwing in the b series i already have but do you think i should buy the motor for 550 with the ecu and be able to make a profit from it thanks Quote Link to comment Share on other sites More sharing options...
Kastigir Posted June 7, 2009 Share Posted June 7, 2009 If you are truly getting a complete swap for $550, then yes you will make a profit off of reselling it. Quote Link to comment Share on other sites More sharing options...
