EFHatchTuner Posted June 4, 2009 Share Posted June 4, 2009 So the dash lights on my '92 hatch dont work and I dont know what it is. All the indicator lights work( check engine, open hatch, no seat belt, etc.) but its just the back lights. Ive had this problem before with my old ef and it was the turn signal arm but the tail lights were also not workin so im clueless. Any ideas? Link to comment Share on other sites More sharing options...
Kastigir Posted June 4, 2009 Share Posted June 4, 2009 Have you checked your little illumination dial to see if there is a short? Link to comment Share on other sites More sharing options...
EFHatchTuner Posted June 5, 2009 Author Share Posted June 5, 2009 No I havnt. I made sure it wasnt as low as possible and also I took apart the dash to make sure all the wiring was ok and it was. Link to comment Share on other sites More sharing options...
sp44 Posted June 29, 2009 Share Posted June 29, 2009 Ever find out what it was? I have the same thing. Everything works but the illumination. Link to comment Share on other sites More sharing options...
SpeedDemon Posted June 29, 2009 Share Posted June 29, 2009 what part of the dash is out? Link to comment Share on other sites More sharing options...
sp44 Posted June 29, 2009 Share Posted June 29, 2009 what part of the dash is out? Gauges and A/C, heater controls. Warning lights work and so does clock. Checked fuses. Link to comment Share on other sites More sharing options...
SpeedDemon Posted June 29, 2009 Share Posted June 29, 2009 Gauges and A/C, heater controls. Warning lights work and so does clock. Checked fuses. my heater/ac lights are starting to dim like yours. the guages may be a bulb behind the dash, shouldnt be that hard to get to. the others should be the same way. if you get the chance pull the dash out and check the lights Link to comment Share on other sites More sharing options...
