seafoam92eg Posted May 20, 2009 Share Posted May 20, 2009 ok so the deal is when im at low rpms and let off the gas and get back on(granny driving)it backfires. if i run the rpms up a lil then it wont do it but below 3k it pops. also seems like its struggling to run if u dont rev pretty descent takein off. its a 92 civic with 96 ls swap. only mods r header/exhaust and cai, brand new plugs so that aint it. i searched and nothin the same came up but if u find sumthin that worked let me kno! thx in advance! Link to comment Share on other sites More sharing options...
Hatch92 Posted May 22, 2009 Share Posted May 22, 2009 sounds like the timing is off Link to comment Share on other sites More sharing options...
lceah Posted May 22, 2009 Share Posted May 22, 2009 I vote timing also! Link to comment Share on other sites More sharing options...
seafoam92eg Posted May 22, 2009 Author Share Posted May 22, 2009 ok so sum guy came by and looked at it and saw that i have the locash racing jumper harness on it and said i needed to run wires to certain sensors and blah blah blah. keep in mind im VERY new to the honda community so i kno almost nothing about any of this stuff Link to comment Share on other sites More sharing options...
Hatch92 Posted May 23, 2009 Share Posted May 23, 2009 did he say what the jumper harness was for? i don't see a need for a jumper harness unless you are running a ODB2 (95+) ecu, however the cure for that would be to run a chipped OBD1 ecu to get rid of said jumper harness i'm still gonna say timing. The check engine light isn't on is it? Link to comment Share on other sites More sharing options...
seafoam92eg Posted May 23, 2009 Author Share Posted May 23, 2009 did he say what the jumper harness was for? i don't see a need for a jumper harness unless you are running a ODB2 (95+) ecu, however the cure for that would be to run a chipped OBD1 ecu to get rid of said jumper harness i'm still gonna say timing. The check engine light isn't on is it? its an obd2 engine so yea its a jumper harness. the cel is on but im sure its because i aint runnin cats. i think imma jus swap to obd1 and get it over with. ive been told its a lot better for stuff like this anyways due to not as many problems. wish me luck! Link to comment Share on other sites More sharing options...
ntone1 Posted May 24, 2009 Share Posted May 24, 2009 timing x2 Link to comment Share on other sites More sharing options...
