rx7turbo287 Posted May 15, 2009 Share Posted May 15, 2009 So i was doing some research on fuel pump and injector. i will be running turbo setup on mine around september-october. well i plan on running 255 walbro, and may be 450 dsm injectors. i was reading on a tech letter on hondata site. http://www.hondata.com/techfuelpump.html so what i understand is i can run stock fuel pump if i running bigger injectors with stock pressure??? may be i read it wrong. Link to comment Share on other sites More sharing options...
Hatch92 Posted May 15, 2009 Share Posted May 15, 2009 you can run a larger injecter with the stock fuel pump. however the stock fuel pump will not flow the volume needed for you to run a larger injector. you would be better off goin with a walbro now and not worring about it later. Link to comment Share on other sites More sharing options...
rx7turbo287 Posted May 15, 2009 Author Share Posted May 15, 2009 so my goal is to run 8 to 10lb the max, need bigger injectors? keep stock pressure and run 255walbro, right? Link to comment Share on other sites More sharing options...
Hatch92 Posted May 15, 2009 Share Posted May 15, 2009 you are gonna probably have to buy a set or get a set out of an eclipse and hack them into your injector harness which is pretty easy, and it's cheap Link to comment Share on other sites More sharing options...
Kastigir Posted May 15, 2009 Share Posted May 15, 2009 For 10 psi you don't need a 255, you will do just fine with a 190. They apparently cost the same, so it's really up to you. Link to comment Share on other sites More sharing options...
Hatch92 Posted May 16, 2009 Share Posted May 16, 2009 ^ that's true. the only down fall is the urge need for more later on down the road. Link to comment Share on other sites More sharing options...
jerrodh Posted May 16, 2009 Share Posted May 16, 2009 It's $100 for the fuel pump w/install kit, it be one of the cheapest parts for your turbo kit lol, get it! GL with build btw I'm throwing a little boost onto my b16 next spring. Link to comment Share on other sites More sharing options...
