boosting b16
rx7turbo287
So i was doing some research on fuel pump and injector. i will be running turbo setup on mine around september-october.
well i plan on running 255 walbro, and may be 450 dsm injectors.
i was reading on a tech letter on hondata site.
http://www.hondata.com/techfuelpump.html
so what i understand is i can run stock fuel pump if i running bigger injectors with stock pressure???
may be i read it wrong.
you can run a larger injecter with the stock fuel pump. however the stock fuel pump will not flow the volume needed for you to run a larger injector. you would be better off goin with a walbro now and not worring about it later.
you are gonna probably have to buy a set or get a set out of an eclipse and hack them into your injector harness which is pretty easy, and it's cheap
It's $100 for the fuel pump w/install kit, it be one of the cheapest parts for your turbo kit lol, get it! GL with build btw I'm throwing a little boost onto my b16 next spring.
