RyanCarter20 Posted May 3, 2009 Share Posted May 3, 2009 b16a2 OBD1 is what were having the problem with. Vtec isn't kicking in at all. I've read through alot of different forums of people having the same problem and I got a few idea's. Seems the most common problems are something to do with oil pressure or faulty wiring. I'm asking for a buddy of mine, he doesn't have internet and I know this is the place to get the best answers so here I am. If you could tell me what the first thing that pops in your head when I say VTEC IS NOT WORKING. I would appreciate it... Link to comment Share on other sites More sharing options...
Kastigir Posted May 3, 2009 Share Posted May 3, 2009 Not enough oil pressure. Link to comment Share on other sites More sharing options...
adamEj6 Posted May 3, 2009 Share Posted May 3, 2009 is the speedo working? Link to comment Share on other sites More sharing options...
RyanCarter20 Posted May 4, 2009 Author Share Posted May 4, 2009 Not enough oil pressure. Thanks man, Thats what we worked on today. I looked to see if the oil pan was dented and everything. Haven't found the problem yet. Still looking.... Link to comment Share on other sites More sharing options...
RyanCarter20 Posted May 4, 2009 Author Share Posted May 4, 2009 is the speedo working? Yeah Link to comment Share on other sites More sharing options...
adamEj6 Posted May 4, 2009 Share Posted May 4, 2009 prolly just not wired rite. you check the codes? Link to comment Share on other sites More sharing options...
Kastigir Posted May 4, 2009 Share Posted May 4, 2009 Check the screen in or near the VTEC solenoid. Sometimes it gets clogged giving a low oil pressure condition. I believe it is inside the solenoid. Link to comment Share on other sites More sharing options...
Zac's Civic Posted June 3, 2009 Share Posted June 3, 2009 I believ it could be your ECU. I belive It would have to be an OBD2 ECU for the B16A2. Did you get it from the 2000 model Si? Link to comment Share on other sites More sharing options...
RyanCarter20 Posted June 5, 2009 Author Share Posted June 5, 2009 Problem solved...crossed wires! It'll do it everytime!! Thanks for the help Link to comment Share on other sites More sharing options...
