95civic Posted April 15, 2009 Share Posted April 15, 2009 I was looking at the injectors on my 95 Civic and they say IPT 4108 any idea what size they are? I also have a set of Python injectors but I can't find any number on them any info is much appreciated Link to comment Share on other sites More sharing options...
Kastigir Posted April 15, 2009 Share Posted April 15, 2009 Stock Honda injectors should run in the mid 200cc range. Link to comment Share on other sites More sharing options...
lastresort576 Posted April 16, 2009 Share Posted April 16, 2009 all civics either use a 240cc or 190cc injector. and there is no advantage in adding a larger injector on a stock set-up...which even includes ihe Link to comment Share on other sites More sharing options...
95civic Posted April 16, 2009 Author Share Posted April 16, 2009 all civics either use a 240cc or 190cc injector. and there is no advantage in adding a larger injector on a stock set-up...which even includes ihe [/quote My car has some mods they are listed in my sig Link to comment Share on other sites More sharing options...
Kastigir Posted April 16, 2009 Share Posted April 16, 2009 all civics either use a 240cc or 190cc injector. and there is no advantage in adding a larger injector on a stock set-up...which even includes ihe My car has some mods they are listed in my sig Did you buy it that way, or add the mods yourself? You're not running stock injectors with a turbo. Link to comment Share on other sites More sharing options...
95civic Posted April 17, 2009 Author Share Posted April 17, 2009 My car has some mods they are listed in my sig Did you buy it that way, or add the mods yourself? You're not running stock injectors with a turbo. I got it the way it is Link to comment Share on other sites More sharing options...
Kastigir Posted April 18, 2009 Share Posted April 18, 2009 I got it the way it is You don't have stock injectors then, if you do you should be running into major fuel cut issues when you get on it. Link to comment Share on other sites More sharing options...
frostedflake Posted April 18, 2009 Share Posted April 18, 2009 yea, stock injectors+turbo=FAIL Link to comment Share on other sites More sharing options...
95civic Posted April 20, 2009 Author Share Posted April 20, 2009 You don't have stock injectors then, if you do you should be running into major fuel cut issues when you get on it. That's what I thought, I will let you guys know what I find out. Thanks Link to comment Share on other sites More sharing options...
