MarineSniper217 Posted April 10, 2009 Share Posted April 10, 2009 So, is there a way to make a boosted Civic not lope like hell? I have about a 400RPM lope range. Cleaned the IAC, FITV, all vac lines sprayed with carb cleaner, no leaks. Would 450cc injectors cause a lope at idle? And smooth out on acceleration Link to comment Share on other sites More sharing options...
Kastigir Posted April 11, 2009 Share Posted April 11, 2009 Did you upgrade cams? Link to comment Share on other sites More sharing options...
MarineSniper217 Posted April 11, 2009 Author Share Posted April 11, 2009 No, factory cam. Link to comment Share on other sites More sharing options...
Blown330 Posted April 11, 2009 Share Posted April 11, 2009 Fuel trims (LTFT) are off. Car is idle hunting because it can't get the right fuel values. Link to comment Share on other sites More sharing options...
MarineSniper217 Posted April 11, 2009 Author Share Posted April 11, 2009 How would I go about fixing that?... Link to comment Share on other sites More sharing options...
Blown330 Posted April 12, 2009 Share Posted April 12, 2009 Depends on what you are using to tune you setup? You using a standalone EFI setup or something that piggybacks on the stock ECU? Link to comment Share on other sites More sharing options...
MarineSniper217 Posted April 13, 2009 Author Share Posted April 13, 2009 The person I bought it from said the ECU was tuned by Chrome to run the setup. A friend of mine who used to run a turbo B18 had his dyno tuned and everything and still loped, he told me most boosted Hondas will do this.... Is that true? Because I would think there would be a way to even it out. Link to comment Share on other sites More sharing options...
alex37211 Posted April 13, 2009 Share Posted April 13, 2009 I've personally seen several boosted Hondas with a smooth idle. Link to comment Share on other sites More sharing options...
Blown330 Posted April 16, 2009 Share Posted April 16, 2009 The person I bought it from said the ECU was tuned by Chrome to run the setup. A friend of mine who used to run a turbo B18 had his dyno tuned and everything and still loped, he told me most boosted Hondas will do this.... Is that true? Because I would think there would be a way to even it out. Tell your friend there is a lot to be said for tuning on the street as well, particularly things that affect driveability. A dyno will only get you in the ballpark, the fine tuning is on the street and track. I can't tell you much as each system is a little different. Find a good EFI tuning forum that supports Chrome and see if someone can point you in the right direction. 99% of the time it's some little fuel trim map that gets overlooked. I can tell you the Long Term and Short Term fuel values should be as close to zero as possible. Those are the values the ECU uses to adjust fueling in closed loop operation to achieve Stoich based on feedback from the O2 sensor. If the base table is out far enough the ECU will continually overshoot/undershoot which is why you get that idle lope. Link to comment Share on other sites More sharing options...
MarineSniper217 Posted April 17, 2009 Author Share Posted April 17, 2009 I dont think it matters too much anymore... I have decided the time and money put into fixing the Civic, all the parts that keep breaking and or leaking, as well as the rusted quarters, leaking trunk, dented all body panels....it will be cheaper to get a different car.... not for a whyle tho. So ill live with the retarded lope for now... 2000 Audi S4, AWD, 6spd, 2.7L and....factory turbo... Only 9k my cost! Link to comment Share on other sites More sharing options...
