C92hatchX Posted March 3, 2009 Share Posted March 3, 2009 i bought a new/used tank cause mine is leaking from the top(only when i put more then 5 bucks in)...can i use my old lines and hoses?, cause the guy i bought the tank from tried to save the lines but idk if they are good or not Link to comment Share on other sites More sharing options...
Kastigir Posted March 3, 2009 Share Posted March 3, 2009 Fuel pump should drop in from above, so it's not really connected to the tank. The only line connected to the tank should be the fuel return line, which just clamps on. Empty tank, remove fuel pump, disconnect return line, drop tank. Installation is reverse of this procedure. Link to comment Share on other sites More sharing options...
C92hatchX Posted March 4, 2009 Author Share Posted March 4, 2009 alright thanks Link to comment Share on other sites More sharing options...
