planedoc Posted December 22, 2008 Share Posted December 22, 2008 I have a 95 Accord LX with the F22B2 engine and it is leaking oil, a steady drip while running, from the lower timing belt cover. I had all the belts and seals changed about 5000 miles ago. Sounds to me after reading that it could be the balance shaft seal. To get the cover off, i am almost certain i have to remove the crankshaft pulley to see what is leaking right? What are the chances the seal is damaged? or just popped out? Any thoughts/help would be appreciated. Link to comment Share on other sites More sharing options...
James Matteu Posted December 22, 2008 Share Posted December 22, 2008 Those seals do not "pop out". Replace the seal, your's is shot. Link to comment Share on other sites More sharing options...
planedoc Posted December 22, 2008 Author Share Posted December 22, 2008 Those seals do not "pop out". Replace the seal, your's is shot. Whats in involved in replacing that seal, if that is it? Link to comment Share on other sites More sharing options...
CleanGSR Posted December 22, 2008 Share Posted December 22, 2008 My accord was leaking from that general area when I got it. It ended up being nothing more than the oil pressure sending unit. Cost about 10 bucks and took about 5 minutes to replace. Link to comment Share on other sites More sharing options...
planedoc Posted December 22, 2008 Author Share Posted December 22, 2008 My accord was leaking from that general area when I got it. It ended up being nothing more than the oil pressure sending unit. Cost about 10 bucks and took about 5 minutes to replace. Well, i know it is coming from inside the cover, from where the oil droplets form. Link to comment Share on other sites More sharing options...
cranny Posted December 22, 2008 Share Posted December 22, 2008 its either a front main seal or cam seal. that woud be my diagnosis. Link to comment Share on other sites More sharing options...
