respusnam55 Posted December 12, 2008 Share Posted December 12, 2008 when i drive my car it runs fine at first but when i stop at stop lights and such the rpms drop almost to where its about to die then it goes back up then back down etc. i cleaned the idle air control valve but made no difference. i found that when i disconnect the connector on thethrottle body and reconnect it it runs fine and doesnt do the idle problem idk what its called or if its what should be replaced. any help is appreciated thanks! oh yeah its a 98 civic ex d16y8 Link to comment Share on other sites More sharing options...
Mafdark Posted December 12, 2008 Share Posted December 12, 2008 may be the obvious answer: Vacuum leak. Check over all your vac lines. Put your ear in the bay and listen for sucking. Link to comment Share on other sites More sharing options...
respusnam55 Posted December 12, 2008 Author Share Posted December 12, 2008 may be the obvious answer: Vacuum leak. Check over all your vac lines. Put your ear in the bay and listen for sucking. will do i covered the throttle body and the car died right away isnt that another way to tell? is there a particular hose i should check? or better way? Link to comment Share on other sites More sharing options...
Mafdark Posted December 12, 2008 Share Posted December 12, 2008 That method isnt exactly fool proof. I personally just check every hose I can find. Link to comment Share on other sites More sharing options...
respusnam55 Posted December 13, 2008 Author Share Posted December 13, 2008 best way to do so? could it be a bad spark plug? Link to comment Share on other sites More sharing options...
Tubbith Posted December 13, 2008 Share Posted December 13, 2008 Sounds like a vacuum leak to me.. No clue as to the best way to check as i have never had to deal with it. Link to comment Share on other sites More sharing options...
respusnam55 Posted December 14, 2008 Author Share Posted December 14, 2008 alright problem fixed finally i ended up changing spark plugs new pcv valve and cleaning the iacv buty the problem was the fuel filter! thanks for ur help~ Link to comment Share on other sites More sharing options...
