JDMEkHatchy Posted December 9, 2008 Share Posted December 9, 2008 is it possible to swap an engine or engine components that are in an automatic car into one that is manual?? Link to comment Share on other sites More sharing options...
Kastigir Posted December 9, 2008 Share Posted December 9, 2008 is it possible to swap an engine or engine components that are in an automatic car into one that is manual?? Yes Link to comment Share on other sites More sharing options...
JDMEkHatchy Posted December 9, 2008 Author Share Posted December 9, 2008 Yes really?? i did'nt know that Thanks Link to comment Share on other sites More sharing options...
frostedflake Posted December 9, 2008 Share Posted December 9, 2008 the only component that you will have to change is the engines ecu. if you put an automatic ecu on a manual car you will always have a check engine light on so just get the manual ecu and you will be set. Link to comment Share on other sites More sharing options...
JDMEkHatchy Posted December 9, 2008 Author Share Posted December 9, 2008 the only component that you will have to change is the engines ecu. if you put an automatic ecu on a manual car you will always have a check engine light on so just get the manual ecu and you will be set. another thing i didnt know lol... thanks Link to comment Share on other sites More sharing options...
lastresort576 Posted December 9, 2008 Share Posted December 9, 2008 the only component that you will have to change is the engines ecu. if you put an automatic ecu on a manual car you will always have a check engine light on so just get the manual ecu and you will be set. ive done it, and didnt get a cel...plus you could always convert the ecu to manual in 2 minutes. if its obd -0/1 that is. Link to comment Share on other sites More sharing options...
JDMEkHatchy Posted December 9, 2008 Author Share Posted December 9, 2008 how do you convert it?? im just curious Link to comment Share on other sites More sharing options...
lastresort576 Posted December 9, 2008 Share Posted December 9, 2008 check out phearable.net Link to comment Share on other sites More sharing options...
frostedflake Posted December 10, 2008 Share Posted December 10, 2008 If you did the swap and didn't get an idiot light than you must have already had the manual ecu in there already. When I put my engine in and started it up, it ran just fine but I had the check engine light on. but when I put the manual ecu in the light went away, and that was the only thing that I touched. Link to comment Share on other sites More sharing options...
