alex37211 Posted October 18, 2008 Share Posted October 18, 2008 I'm looking at getting a Carsound / Magnaflow cat. I'm using an obd2 b18c1 (97 GSR) with an obd1 p72 ecu (95 GSR). My stock 95 civic cat has no O2 sensors in it. A 95 GSR cat has one. A 97 GSR has 2!! Will I have to use a 1-sensor cat with that ecu to prevent the check engine light from appearing? If so, would I need to wire it into the obd1 p72 ecu? Also, If I used the sensor-less cat, could I bypass the emissions part of the ecu and avoid a check engine light? thnx Link to comment Share on other sites More sharing options...
alex37211 Posted October 23, 2008 Author Share Posted October 23, 2008 Alright! 38 views and not one response. Link to comment Share on other sites More sharing options...
Kastigir Posted October 23, 2008 Share Posted October 23, 2008 If I'm not mistaken, and OBDI car only looks for one O2 sensor. As long as you're running one, you shouldn't get a CEL. Is there a hole for one in your manifold before the cat? Link to comment Share on other sites More sharing options...
frostedflake Posted October 26, 2008 Share Posted October 26, 2008 The hell with a cat just get a test pipe, I did. unless you live in CA, than thats a different story. and you besta be going to that import alliance meet alex, seeing as you are right there. Link to comment Share on other sites More sharing options...
