Washer Nozzle Posted October 15, 2008 Share Posted October 15, 2008 Where exactly is the fuel pump I think its my problem so i need to remove it The problem is i herd i have to drop the gas tank to get to it.... and the rods that support the straps holding the tank is rusted to SH*T is there any way to get to it without dropping the tank??Unless you guys think its a different problem... **Problem** Engine turns almost starts but doesnt I can spray a light mist of fuel into the carb and it will start and if i keep spraying lightly it keeps running but once i stop spraying it dies.... I know its not good to do this but I need to test it some how I think the pump has gone bad from sitting around so long and the fuel is also old..... PLEASE I NEED HELP ANY WOULD BE APPRECIATED Thanks Link to comment Share on other sites More sharing options...
Kastigir Posted October 15, 2008 Share Posted October 15, 2008 Should be able to remove the rear interior and access it from inside the car. Link to comment Share on other sites More sharing options...
Washer Nozzle Posted October 16, 2008 Author Share Posted October 16, 2008 Should be able to remove the rear interior and access it from inside the car. Theres no access from the inside of the car unless i cut a hole in the metal.. Link to comment Share on other sites More sharing options...
lastresort576 Posted October 16, 2008 Share Posted October 16, 2008 Theres no access from the inside of the car unless i cut a hole in the metal.. exactly what a buddy of mine did on his rex, so he wouldnt have to drop the tank. he basically made it the same way you would find the fuel pump access in a 92-95 civic by sourcing one of the covers in the junk yard. good luck! and if you dont cut it you have to drop it. Link to comment Share on other sites More sharing options...
