tfawbush Posted May 14, 2002 Share Posted May 14, 2002 Has anyone ever left their gas cpa off of a crv and had the engine light come on? If so how do you get it to go off? Does this cause damage to the engine? Thanks, Tom Link to comment Share on other sites More sharing options...
0verb00st Posted May 14, 2002 Share Posted May 14, 2002 my explorer does that. it's because the fuel system is pressurized. with the cap off, it cant build up pressure. to reset the code on my explorer, you have to disconnect the battery for 20 minutes. maybe it's the same with the CRV Link to comment Share on other sites More sharing options...
TrueSi Posted May 14, 2002 Share Posted May 14, 2002 No it doesnt cause any damage to your engine Link to comment Share on other sites More sharing options...
XScarAudio Posted May 21, 2002 Share Posted May 21, 2002 same on hondas....to reset the ECU, pull the neg. from the battery and let it sit for 20 min or so. Link to comment Share on other sites More sharing options...
boost Posted May 22, 2002 Share Posted May 22, 2002 All 96 and newer vehicles do this, as the OBDII system requires the fuel tank to be a closed system under a certain pressure. No harm tho. Link to comment Share on other sites More sharing options...
