dez2121 Posted August 3, 2008 Share Posted August 3, 2008 I cant get my car to start by turning the ignition. i can bypass everything @ the starter by sending 12 volts to the solinoid, and the car will start. The starter and solinoid have been pulled off and tested several times and both are good. I have replaced my ignition switch,neutral safety switch,and all grounds. Still not getting any change, also im not getting power to half of my interior fuse box.Im without transportation please help, i need all the help i can get. Link to comment Share on other sites More sharing options...
SIR_VTEC Posted August 4, 2008 Share Posted August 4, 2008 If you say the started and solenoid are good, then maybe you just need to check the wires, spark plugs...worst case would be the coil packs in the distributor, there fore needing your whole distributor replaced and not just the cap & rotor Link to comment Share on other sites More sharing options...
dez2121 Posted August 4, 2008 Author Share Posted August 4, 2008 2 days before i started having this problem I replaced all the plugs, wires,cap and rotor. i've check all my connections and wires and all are tight and good. The distributor is brand new i've only had it about 2 months. Link to comment Share on other sites More sharing options...
slosol Posted August 25, 2008 Share Posted August 25, 2008 i had the exact same problem with my 89 crx si. on mine it turned out to be a wire that runs from the ignition swith to the starter solenoid itself, had a short in it. instead of tracing the wire i got a haynes manual checked the wiring diagram. then i figured out which terminal on the ignition led to the solenoid and ran a new wire. ran it thru some existing wire loom, a little electrical tape and it was good to go. if this is your problem, just be sure and use the proper guage wire and either solder. Link to comment Share on other sites More sharing options...
