jkm345 Posted July 7, 2008 Share Posted July 7, 2008 i have white smoke coming out my tail pipe whenever i downshift, i was told that it could be my head gasket that needs replacement or that i need to replace my pistons, because i have high compression pistons..any help would be appreciated. Link to comment Share on other sites More sharing options...
2gboostedteg Posted July 10, 2008 Share Posted July 10, 2008 This happened to a friend of mine on his gsr and it turned out to be the intake manifold gasket, it might be that for you. Link to comment Share on other sites More sharing options...
Rick B. Posted July 10, 2008 Share Posted July 10, 2008 white smoke tends to be a problem with a coolant leak somewhere, usually the head gasket. its better to be safe than sorry. replace your gaskets and see if that fixes the problem. if not, move onto the next possible solution white smoke = steam blue smoke = oil Link to comment Share on other sites More sharing options...
